door on oven was open - the oven clean button was pressed and set while the door was still open-- now the door will not close and the lock is set and lock light is flashing. How do I reset it?
Push and hold the oven light switch on the door frame. Push the Start button. Wait a few seconds and push the Cancel button. Release the oven light switch after the display will reset to the time mode.
Originally Posted by: Gene  Push and hold the oven light switch on the door frame. Push the Start button. Wait a few seconds and push the Cancel button. Release the oven light switch after the display will reset to the time mode.
Gene. thanks it worked
You are welcome. I'm glad you were able to fix it.
