AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Whirlpool Duet, burner shts off after a few seconds
My Whirlpool Duet will run but has no heat. I checked the termal fuse, it was bad, replaced it. Now the burner will light for about 5 to 10 seconds, then there is a click and it shuts off, it will repeat this in about 3 to 5 min.
I have cleaned the dryer vent and I am still having this problem.
thanks
Could be a bad coil on the gas valve.
Originally Posted by: ApplianceJunk Could be a bad coil on the gas valve. I will give that a try and keep you posted. thanks,
Dryer Repair
