djnettleton
#1 Posted : Sunday, December 25, 2011 10:24:23 AM(UTC)
djnettleton
washer fills and drains but water wont circulate...removed down to & including the chopper assembly & check value. can spin the impellar. thought I had a bad motor so wanted to see if it spun. since it does what do I do next
ApplianceJunk
#2 Posted : Sunday, December 25, 2011 10:52:16 AM(UTC)
ApplianceJunk
The motor could still be bad.
I would check to see if I'm getting voltage to the motor during the washer cycle. If you have voltage to the motor, but it does not run I would replace the motor.
djnettleton
#3 Posted : Monday, December 26, 2011 9:38:24 AM(UTC)
djnettleton
How do I check to see if the motor is getting voltage during the washer cycle
