I have a 3-year old Whirlpool Dishwasher (Model DU1055XTSQ3) which was leaking small amounts of water. I found small amounts of water beneath the left door hinge. I replaced the rubber door gasket that lines the sides and top of where the door and dishwasher meet. This fixed the problem, but only for a couple of months. The gasket appears to be in very good shape. I'm wondering if anyone would know where else to look for the source of this leak. Underneath the dishwasher itself appears to be dry. The water I find on the floor has some black stuff in it too, presumably lubricant from the door hinge.
I read in another thread to also check to see if the door was level (as this may indicate a bent door hinge), and it was level.
Any help would be much appreciated! Thanks.
