11jamesb11
#1 Posted : Friday, December 16, 2011 6:38:52 AM(UTC)
11jamesb11
James Bradshaw: my admiral side by side frig is not cooling. i took
the back off cleaned and notice the compressor is not running.
i checked with a volt meter and there is power to the compressor.
the compressor is not hot. i don't here any humming or clicking or anything
besides the fans running.
Gary/APP Team
#2 Posted : Friday, December 16, 2011 7:03:31 AM(UTC)
mattt
Hello James. Lets see if I can walk you thru this,what we are going to test is your compressor since you have an ohms meter first lets put it on the ohms reading Ω Ok unplug the unit. take that little cover off the side then take a small screwdriver and pry the overload and relay off the three pins sticking out of the side of the compressor.Ok there are three pins they should be in a triangle the top one is your neutral then the two bottom ones are the start windings and the other is the run windings. take your red lead and put one of the bottom pins and the black lead on the other bottom pin so you are taking a reading from the start winding and the run winding.Ok you with me, remember the triangle ok you got a reading across the two bottom pins that shouldn't have been over 12 ohms ok now go from the top pin which is the neutral to the start winding ok whatever your reading is across the two bottom pins lets say its 10 thats perfect so from the top pin to either one of the bottom pins should be 5 and the other side from the top pin to the run winding should be 5 as well they have to be equal so if the reading is 10 like we said one side cant be 8 and the other side 2 do you see what I mean it should be really close if they are way off like 8 to 2 the windings in the compressor are bad you can also check the overload and relay put the ohm meter on buzz so that when you touch the leads together you can hear it buzz stick the leads into the two bottom holes you should hear it buzz if not its bad I hope this helps. Thank You and Good Luck !
11jamesb11
#3 Posted : Friday, December 16, 2011 7:45:08 AM(UTC)
11jamesb11
Originally Posted by: Gary/APP Team Go to Quoted Post
Hello James. Lets see if I can walk you thru this,what we are going to test is your compressor since you have an ohmn meter first lets put it on the ohmns reading Ω ok unplug the unit. take that littlte cover off the side then take a small screwdriver and pry the overload and relay off the three pins sticking out of the side of the compressor.Ok there are three pins they should be in a triangle the top one is your nuetral then the two bottom ones are the start windings and the other is the run windings. take your red lead and put one of the bottom pins and the black lead on the other bottom pin so you are taking a reading from the start winding and the run winding.Ok you with me remember the triangle ok you got a reading across the two bottom pins that shouldnt have been over 12 ohmns ok now go from the top pin which is the neutral to the start winding ok whatever your reading is across the two bottom pins lets say its 10 thats perfect so from the top pin to either one of the bottom pins should be 5 and the other side from the top pin to the run winding should be 5 as well they have to be equal so if the reading is 10 like we said one side cant be 8 and the other side 2 do you see what I mean it should be really close if they are way off like 8 to 2 the windings in the compressor are bad you can also check the overload and relay put the ohmn meter on buzz so that when you touch the leads together you can hear it buzz stick the leads into the two bottom holes you should hear it buzz if not its bad I hope this helps. Thank You and Good Luck !
i can do these test no problem. thanks for your good instructions.
i will post my results. it may be a day or two.
11jamesb11
#4 Posted : Wednesday, January 11, 2012 7:49:56 AM(UTC)
11jamesb11
I about forgot to post my results. The windings in the compressor checked good. So I checked the overload switch and it was open. Another way to tell if the overload switch is bad is shake it. If it rattles its probably bad. After I had the new one on the way I took the old one apart to see what was going on in there. The rattling was parts of the burnt switch lose in the casing. Anyway got my part from appliance pro in a couple of days and back to cooling. Thanks for the help. You saved me $.
Gary/APP Team
#5 Posted : Wednesday, January 11, 2012 8:02:42 AM(UTC)
mattt
Thanks we are always glad to help, with all your repair needs,again Thank you and good luck !
Refrigerator Compressor Starting With Failed Start Relay??? How Can This Be? (Refrigerator & Freezer Repair)
by AppliancePartsAmateur 7/1/2024 5:18:48 PM(UTC)
GTS16DTNKRWW Refrigerator - Intermittent Operation (Refrigerator & Freezer Repair)
by seocom 6/22/2024 6:51:32 AM(UTC)
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Whirpool WRF535SMBM Refrigerator (Refrigerator & Freezer Repair)
by goclones 6/16/2024 8:15:11 AM(UTC)
Samsung Refrigerator Pantry Drawer Support #SAM-DA61-03174A (Refrigerator & Freezer Repair)
by joecoliphant 6/15/2024 8:12:03 AM(UTC)
Ice behind fan pannels in refrigerator and fan not working (Refrigerator & Freezer Repair)
by Mark7604 6/9/2024 6:43:14 AM(UTC)
GTR22HBTARBB water leak to bottom refrigerator (Refrigerator & Freezer Repair)
by wilsonjiaho 6/8/2024 4:24:50 PM(UTC)
LG Refrigerator - Makes ice, but won't dispense ice nor water (Refrigerator & Freezer Repair)
by teamfindley 5/28/2024 7:48:32 PM(UTC)
samsung fd refrigerator (Appliance Repair Companies - East of the Mississip)
by gale reid 5/28/2024 3:17:33 PM(UTC)
Cold-Coldest setting on meat drawer on GE GNE25j refrigerator (Refrigerator & Freezer Repair)
by Guest 5/23/2024 11:20:53 AM(UTC)
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 5/16/2024 12:29:58 PM(UTC)
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
Refrigerator Ice (Refrigerator & Freezer Repair)
by Guest 5/9/2024 7:00:37 AM(UTC)
GE refrigerator Ice machine not working. (Refrigerator & Freezer Repair)
by Don718 5/6/2024 11:45:46 AM(UTC)
