top of side by side won't cool, but bottom will. have cleaned coils and replaced automatic defrost switch:confused:
Here are your parts Replacement parts for WHIRLPOOL ED25RFXFN01 SIDE BY SIDE REFRIGERATOR | AppliancePartsPros.comWhich side is not cooling properly or is it both sides? Check that the vent between the sections lower down on the separating wall is clear of food etc. on both sides. It should be for proper air circulation. Is the evaporator/freezer fan running? It sounds like for some reason you do not have proper air flow in the unit so the cold air is settling at the bottom. |
THIS FORUM IS DEAD!!!!!!! |
