tjones0737
#1 Posted : Wednesday, November 30, 2011 12:24:53 PM(UTC)
tjones0737
My dryer would not tumble if it had more than 1 or 2 towels and now it will not heat up at all. Could this be related, or 2 seoarate problems? I am thinking it is the belt and the heating element, but not sure how the tumbler works and if it would keep it from heating.
#2 Posted : Thursday, December 1, 2011 5:10:46 AM(UTC)
Here are your parts, includes a wiring diagram.
Replacement parts for MAYTAG HYE3658AYW DRYER- ELE | AppliancePartsPros.com
Yes the two problems could be related.
If the motor is struggling to turn the drum then you would also have lower air flow through the unit as the blower is directly connected to the motor. This then could blow the thermal fuse or even the heating coil.
Try turning the drum in the correct direction by hand. It should turn fairly easily. You may wan to try this on a couple other dryers to get a feel for it.
If it is hard to turn you will have to open the unit up and find out why.
If it turns OK then odds are that the motor is on it's last legs.
I would find troubleshoot the motor problem first and then check the heating problem.
Dryer Repair Again and Again (Dryer Repair)
by Guest 6/25/2022 3:48:47 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Dryer repairs (Dryer Repair)
by P3FE 10/16/2021 2:36:49 PM(UTC)
Whirlpool Dryer Repair Mishap (Dryer Repair)
by Clanky3 3/19/2020 12:26:10 PM(UTC)
Dryer Repair Issue (Dryer Repair)
by jdharrin 10/2/2019 1:32:57 PM(UTC)
THIS IS A 'PICKLE', on my dryer repair (Dryer Repair)
by Polly147 2/2/2018 5:35:41 PM(UTC)
Dryer repair Help! (Dryer Repair)
by Hah45 10/4/2017 2:39:32 AM(UTC)
Frigidaire dryer Gallery series wont heat in Dryer Repair. "dryer turns but no heat (Dryer Repair)
by darien685 8/24/2016 11:36:06 AM(UTC)
dryer repair Amana (Dryer Repair)
by rlblaxstick@aol.com 12/26/2015 12:03:59 PM(UTC)
Dryer Repair (Dryer Repair)
by sotomargie 12/21/2015 9:44:35 AM(UTC)
Dryer repair (Dryer Repair)
by dchurch 9/26/2015 8:38:17 AM(UTC)
by jaybick 8/24/2015 6:34:15 AM(UTC)
Cordless screwdriver for dryer repair ? (Dryer Repair)
by dog_at_work 10/13/2014 10:54:09 AM(UTC)
by Tom Campion 4/14/2014 6:20:19 AM(UTC)
by kencorey281@gmail.com 11/12/2013 2:35:48 PM(UTC)
