I ordered switch number 9871101. I received replacement part number 9872161. The original rocker switch has a pilot light and four terminals for four wires. The replacement has no pilot light and only has three terminals. I can live with that but I'm not sure what to do about the remaining wire. Does a jumper terminal need to be used to hook all the yellow wires up? Can the oem switch be obtained?
