James chris
#1 Posted : Saturday, September 10, 2011 10:14:46 AM(UTC)
James chris
Hello
I have a washing machine model (WISR309DGBWW).
1- the cold water flows in perfectly fine but the hot water doesn't why is this?
2- Is there an electric fuse in the hot water in the in the washer model (WISR309DGBWW) (that resists a strong electric shock) on the fuse and that's why the hot water doesn't want to flow in cause the fuse burned out which stops the electricity from letting the water in.
3-if the fuse burned out does it stop the water from flowing in the washer?
4-for my washing machine (WISR309DGBWW) can i place somthin small like a fuse or something else small in the washer that would make the washer heats the water in the washing machine?
thanks
sidfink43
#2 Posted : Sunday, September 11, 2011 5:07:22 PM(UTC)
sidfink43
There is no fuse here.
Switch the connectors on the hot and cold water valve assembly. If cold water flows and the hot water does not flow when you set the selector to hot, the water valve is not opening for hot and needs to be replaced. If hot water comes out when cold water is selected and cold water does not come out when hot water is selected the problem can be in the timer or the water selection switch.
James chris
#3 Posted : Tuesday, September 13, 2011 7:41:19 AM(UTC)
James chris
thank you very much and i really appreciate your answer and help i have been searching for my problem for like a month anyways last question can i put something inside the washer like a spare part so the washer can heat its own water?
thank you again :)
sidfink43
#4 Posted : Tuesday, September 13, 2011 11:31:11 AM(UTC)
sidfink43
Uh, no. Don't think that will work
James chris
#5 Posted : Saturday, January 28, 2012 3:47:45 AM(UTC)
James chris
Hi sidfink43
My problem with the hot water happens to happen again with me but this time the hot water doesn't want to flow into the washer machine but when we got a bucket and directed the hot water's hose into it the hot water started to flow easily.
Is there any solution for my problem
thanks
Chris James
