Hello i have a roper drye r replaced drum rollers tension wheel drum felt front and rear. Makes a bad noise when you first start it up. Thanks with your help.
If it's kind of a rumbling noise, and especially if it occurs on start-up, it is likely to be a loose blower fan. Part number: AP2997251
