Washer will be in the middle of its wash cycle and then start beeping and the green lights start flashing. Then for awhile it will quit then start doing it again. Washer still goes thru its full wash cycle without stopping. Then some days it will not do it at all even for a few weeks at a time. i do about 3 to 4 loads a week. i have had the washer since 05/2007. Bought new not used from Lowes. The model# LTF2140FS0 Serial# XC72010302 ...
If you could help me trouble shot what the problem is that would be great..
Thank You Dave..
Look inside the lower service panel and you should find some tech notes. The machine may be trying to send you an error message and the tech notes will tell you how to read it.
