My washer stopped spinning and agitating. Belt is fine...like new. But when I opened the front of the washer, I found small pieces of metal and metal filings directly under the clutch assembly. Motor spins fine. I noticed on the motor there is a hole on the shaft that looks like it holds a pin to connect with the clutch but it is not there. Any suggestions?
