atoner
#1 Posted : Monday, August 1, 2011 4:12:54 AM(UTC)
atoner
:confused: my inglis washing machine will not wash in cold water setting. it will wash in other temps. what do i need to do?
sidfink43
#2 Posted : Wednesday, August 3, 2011 5:22:46 PM(UTC)
sidfink43
If it will rinse, which uses cold water then the cold water valve is ok so it is either the timer or temp switch. Try replacing the temp switch, this part here.
Part number: AP3890456
atoner
#3 Posted : Tuesday, August 9, 2011 7:18:59 AM(UTC)
atoner
Thank you for your advice!! Since my original question it has worked in the cold setting a few times but quits after 2-3 loads. It will rinse in cold during those 2-3 times. It will also stop during a cycle just before the final rinse and spin. ??????? So confused!!!! :(
sidfink43
#4 Posted : Tuesday, August 9, 2011 10:13:06 AM(UTC)
sidfink43
See if it will wash in the cold or warm setting and in the warm setting make sure you are getting warm and not hot.
We need to rule out or rule in the valve assembly.
atoner
#5 Posted : Tuesday, August 9, 2011 10:16:55 AM(UTC)
atoner
In the warm setting it only washes in HOT. And the stopping during a cycle happens occasionally, and during any of the temp settings.
sidfink43
#6 Posted : Tuesday, August 9, 2011 3:06:01 PM(UTC)
sidfink43
I would change out the valve assembly and see if that fixes the temp thing.
atoner
#7 Posted : Wednesday, August 10, 2011 4:29:54 AM(UTC)
atoner
do you have a part numer for the valve assembly? Thank you so much for all your help!!
sidfink43
#8 Posted : Wednesday, August 10, 2011 6:14:23 AM(UTC)
sidfink43
Here is the part, which is much more complex than most valve assemblies and much more expensive. Sorry about that
Part number: AP4354804
If you buy from this site and the part does not fix the problem you can return it, see the returns policy for details and conditions.
Good luck
Frigidaire Affinity Washing Machine - Leaking only sometimes (Washer Repair)
by omf_24 2/24/2024 4:45:41 PM(UTC)
Stem question about Naytag 2-belt washing machine (Washer Repair)
by Hotrodjohn71 1/2/2024 7:50:48 AM(UTC)
Maytag Oasis HE Washing Machine (Washer Repair)
by Guest 12/8/2023 12:55:45 PM(UTC)
Whirlpool Washing Machine won't start/fill (Washer Repair)
by greekguy7 12/8/2023 4:53:34 AM(UTC)
whirlpool model wtw7300dw2 washing machine (Washer Repair)
by Guest 11/8/2023 9:27:17 AM(UTC)
MVWB965HC0 Washing Machine - Need Service Manual or Video to Replace Touchpad and Control Assembl (Washer Repair)
by Guest 10/30/2023 8:11:10 PM(UTC)
Best vintage, American made washing machines (Washer Repair)
by Guest 10/30/2023 5:27:34 AM(UTC)
Washing machine not washing clothes properly (Washer Repair)
by Guest 9/20/2023 11:56:24 AM(UTC)
Washing Machine fill with water but will not spin, rinse or agitate. (Washer Repair)
by jmaiso 9/1/2023 7:04:07 AM(UTC)
Washing machine do not complete the cycle (Washer Repair)
by Guest 8/16/2023 10:02:15 AM(UTC)
Mayag washing machine - possibly locked motor? (Washer Repair)
by crp0499 5/19/2023 3:02:19 AM(UTC)
Recommended replacement for WP22001311 Maytag Washing Machine Unbalance lever (Washer Repair)
by Guest 4/29/2023 12:17:37 PM(UTC)
Whirlpool washing machine drive hub (Washer Repair)
by Guest 4/23/2023 7:29:26 AM(UTC)
Extension hose for GE washing machine GFW850SPNRS (Washer Repair)
by Guest 3/17/2023 9:53:53 PM(UTC)
Maytag washing machine MHW6630HW - looking for electrical diagram (Washer Repair)
by jessman1128 2/8/2023 12:45:11 PM(UTC)
