victorarbuet
#1 Posted : Wednesday, December 10, 2008 4:09:55 PM(UTC)
victorarbuet
My whirpool duet washer, one day i found water on the floor and realized that water was coming out of the washer. It was hot water, then put machine into spin and took water out. Then hot water kept coming out. So I closed the hot water faucet and that fixed that problem. Couple days later the washer stops when is into a wash cycle and it gives me the code for FH, which I found out that is no sufficient water. I checked the hose and the water inlet and is clean and there is water pressure. Can anybody help?
libertyappl
#2 Posted : Wednesday, December 10, 2008 5:01:55 PM(UTC)
libertyappl
Check your water valve.
Nat
#3 Posted : Wednesday, December 10, 2008 7:13:32 PM(UTC)
Here is your parts breakdown
Model GHW9400PW0
Check the water level switch and the pressure hose attached to it
Make sure the hose is not cracked or brittle and that it fits tightly to the fitting. Item 23 in "Top and cabinet parts" section
If you have not already done so check that there are no dirty filter screens in either the hoses or the water valve (inlet side)
This may also help (tech sheet)
https://www.servicematters.com/d...0Sheet%20-%208182277.pdf
Whirpool Duet GGW9250PL0 won't start/spin (Dryer Repair)
by Smallbej 2/18/2020 7:09:30 PM(UTC)
Whirpool Duet Sport won't run Diagnostic Test (Washer Repair)
by RIPPTA 11/19/2019 1:28:05 PM(UTC)
Whirpool duet Dryer (Dryer Repair)
by Louiella 1/23/2018 1:55:01 PM(UTC)
Whirpool Duet (first gen) (Dryer Repair)
by jmden 8/23/2017 7:03:25 AM(UTC)
my whirpool duet dryer wont heat (Dryer Repair)
by bluelake78 12/18/2016 7:01:30 PM(UTC)
Whirpool Duet F70/F71/Beep Error (Washer Repair)
by ADS66 9/30/2015 5:54:08 AM(UTC)
Whirpool Duet Issues (Dryer Repair)
by joshhaye44 6/20/2015 11:11:50 AM(UTC)
Whirpool duet washer leaks water+detergent after load finished (Washer Repair)
by waylo 1/25/2015 9:47:32 PM(UTC)
Whirpool Duet Washer new circut board wont work F11 code still up (Washer Repair)
by Rickvial88 7/10/2013 7:33:37 AM(UTC)
whirpool duet (Dryer Repair)
by jesquivel98 4/9/2013 9:43:06 PM(UTC)
Whirpool Duet (Washer Repair)
by spencer5 12/6/2012 6:15:05 AM(UTC)
Whirpool Duet Dryer - Just Stopped! (Dryer Repair)
by Gary Prentice 12/7/2011 6:37:20 AM(UTC)
whirpool duet f06 fault (Washer Repair)
by jeff and Susan Coffing 11/8/2011 4:32:51 PM(UTC)
whirpool duet washer door is not opening staying locked (Washer Repair)
by sonya46 10/23/2011 6:12:22 AM(UTC)
Whirpool Duet Sport Washer (Washer Repair)
by MBKeith 7/18/2011 9:51:09 AM(UTC)
