replaced the door lock control.... still turning on & off and never getting any where. no error code because it wont stay on long enough to see. w/ door open or closed:eek: it will turn on for 3 secs then off for 2 then on for1/2sec off on off on etc
Inside the lower service panel there should have been some tech notes that would tell you how to troubleshoot it, but sounds like that cannot be done, so changing out the main control is your likely solution.
