GE Front Load Washer won't start - model WBVH6240FWW
Most likely the problem is a bad control board because the washer does not go into the test mode. The decimal point is not listed anywhere as a fault code. Actually it is not listed at all. The part number for the control board I posted earlier.
I’ll try to invite abadfish66 to review this problem. He is the best GE expert on the forum.
