[quote=Gene;47392]In order to enter the test mode you have:
Press the “power” button to clear any current cycles (the display must be blank to proceed)
Unplug the washer for 30 seconds
Plug it back and within 30 seconds of reconnecting power press signal-delay start-signal delay start
The door should lock then will display “t01”.
Gene.[/quote]
Gene,
My apologies for using the wrong terminology, I wasn’t in front of the machine when I last responded. I have done what you describe and the door does not lock and “T01” does not appear in the display. The display remains dark/off and I get 2 beeps but nothing else. Just for clarity I did the following steps.
- Machine plugged in, door closed - push power button to turn it off (display blank)
- Unplug machine for at least 30 sec
- Plug machine back in and within 30 seconds push signal-delay start-signal-delay start
- Hear two short beeps but no door lock and no “T01” (i.e. display remains blank/off)
Is there some other way to “clear” the control board?
I have cleaned the filter/drained the water from the tub. I also checked the water level/pressure switch and the contacts are in the appropriate position for an empty tub (service manual, page 33).
It seems to me that the decimal point in the display must mean something/come from somewhere but I sure don’t understand it or how to clear it…
Any other thoughts/suggestions will be most appreciated! Thanks.
