[QUOTE=Gene;47341]Try to reprogram the control board, following these instructions:
Enter the test mode and select “t01”
Rotate the cycle knob until the correct model number is displayed - “3” for model WBVH6240F
Press and hold the “Start” key for 3 seconds (or until a second beep is sounded)
Press the “Power” key to reset the control.
If it would not help then replace the control board. You have to program the new control board according to above instructions.
- The part number for the control board is AP3995160
Gene.[/QUOTE]
Thank you Gene. One problem I have, however, is that I don’t seem to be able to enter the Test mode. When I push the prescribed “Loud-delay-loud-delay” button sequence I get two beeps but the display is blank. Am I doing something wrong or does that in and of itself mean that the control board is bad?
