GE Front Load Washer won't start - model WBVH6240FWW
Try to reprogram the control board, following these instructions:
Enter the test mode and select “t01”
Rotate the cycle knob until the correct model number is displayed - “3” for model WBVH6240F
Press and hold the “Start” key for 3 seconds (or until a second beep is sounded)
Press the “Power” key to reset the control.
If it would not help then replace the control board. You have to program the new control board according to above instructions.
  • The part number for the control board is AP3995160
