biggin65
#1 Posted : Sunday, May 29, 2011 2:58:22 PM(UTC)
biggin65
hi my freezer & refridge are geting too cold freezer 10 to 20 below and my fridge is 20 to 30 deg can you help on what part i need to replace and part# if possible. thanks,:) the refridge is on low setting.
#2 Posted : Monday, May 30, 2011 3:01:25 AM(UTC)
Are yoy sure it is "1006" and not 106.
The following is for a 106 unit.
Replacement parts for KENMORE 10652569100 | AppliancePartsPros.com
See the attachment for the tech sheet
Here is a manual which I think is applicable.
http://appliancedigest.c...c-control-service-manual
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
Have you tried disconnecting power from the unit for 5 minutes or so to see if the board will correct itself?
Try the thermistor diagnostics test.
If OK, check the thermistor resistances with a meter and connectors.
IfOK, the board is probably bad.
File Attachment(s):
52569100.pdf (1,490kb) downloaded 8 time(s).
biggin65
#3 Posted : Monday, May 30, 2011 7:48:25 AM(UTC)
biggin65
hi 10652569100 so think its the board and that located on freezer side right;
#4 Posted : Monday, May 30, 2011 8:01:58 AM(UTC)
If you look at the Sears parts site it will give you a parts layout.
