I'm trying to fix a whirlpool icemaker with the optic system. First, I could get nothing reliable to happen with the red LED in the freezer. Mostly, it would be off. I replaced the pc boards. Now, first I got the 4-5 second solid on, then two blinks and one second delay. I understand the LED is supposed to be on constantly with (freezer door switch open) for the system to work. I'm hoping I haven't changed the pc boards unnecessarily. Do I need to jump the T to H terminals to start it?
I am having problems with the optics on my Whirlpool icemaker as well. It appears to be the optics. Was it difficult to switch the boards out? (In other words, is this best left to an experienced repair man or can someone reasonably handy handle this?)
No, mckeejohnson, it's not difficult. Unplug the refridgerator first, and be careful with the connector lock (plastic).
My question is- if the water dispenser in the door works, does that mean the fill valve is also working?
I'm not getting the usual click and solenoid noise at the end of the harvest cycle.
When you open the freezer door, the red led should be blinking showing interrupted optics. If you close the flapper on the left, the led should be steady, then go out when you close the door switch, shining in invisible mode. If anything intermittent, you probably have bad refrigerator wiring, very difficult to fix.
The optics work perfectly. I just don't get water in at the end of the harvest cycle. I don't even hear the click of the solenoid, so either the solenoid is bad, or the icemaker is not sending the signal to the solenoid.
Does the water inlet valve use the same part as the drinking water supply? The glass filler valve does work.
Originally Posted by: benmadden The optics work perfectly. I just don't get water in at the end of the harvest cycle. I don't even hear the click of the solenoid, so either the solenoid is bad, or the icemaker is not sending the signal to the solenoid.
Does the water inlet valve use the same part as the drinking water supply? The glass filler valve does work. Ben, No, the fridge has a dual solenoid fill valve, one for the water dispenser, and one for the ice maker. Part number: AP3160649
The proper test would be to disconnect the wires from the ice maker valve (green solenoid) ,attach your meter probes to the wire terminals and jump T to H at the control module, and check for 120 VAC, when the ice maker reaches the fill segment of the cycle, no voltage, bad wire or ice maker, if you have the voltage, bad fill valve. Good Luck, :cool: :cool: :cool:
Originally Posted by: Joe / APP Team Ben, No, the fridge has a dual solenoid fill valve, one for the water dispenser, and one for the ice maker. Part number: AP3160649
The proper test would be to disconnect the wires from the ice maker valve (green solenoid) ,attach your meter probes to the wire terminals and jump T to H at the control module, and check for 120 VAC, when the ice maker reaches the fill segment of the cycle, no voltage, bad wire or ice maker, if you have the voltage, bad fill valve. Good Luck, :cool: :cool: :cool: Thanks, Joe
Originally Posted by: benmadden Thanks, Joe Ben, You're welcome, it's my pleasure to assist. Let us know what you find. Thanks, :) :) :)
