dale farnes
#1 Posted : Monday, May 23, 2011 1:40:01 PM(UTC)
dale farnes
i have a problem withh ice maker it seems to overfill creating an ice waterfall from the ice maker down to the bottom of the freezer any suggestions or thoughts is it a problem of to much water pressure or not level?
Roger_lv
#2 Posted : Monday, May 23, 2011 4:10:12 PM(UTC)
Roger_lv
Changed the ice maker and that work for about 4 months then started leaking again. Ice trays are a pain, but cheaper then the repair cost.
Roger_lv
#3 Posted : Monday, May 23, 2011 5:24:47 PM(UTC)
Roger_lv
Originally Posted by: badu789 Go to Quoted Post
Please check if the lever for the incemaker tray is in correct position.
The lever sweeps normally.
#4 Posted : Monday, May 23, 2011 7:38:16 PM(UTC)
Most likely the problem is a bad water inlet valve on the back of the refrigerator which stacks open.
- The water inlet valve Part number: AP3192626
#5 Posted : Monday, May 23, 2011 7:39:22 PM(UTC)
Roger,
Are you sure the problem was the ice maker from the beginning? Or may be it was the ice maker and now it is a bad water valve?
Unfortunately nothing last forever.
Roger_lv
#6 Posted : Tuesday, May 24, 2011 7:17:52 AM(UTC)
Roger_lv
Thanks Gene. I'll try changing the valve. Maybe it's sticking. We get a lot of sediment in our lines.
#7 Posted : Tuesday, May 24, 2011 12:43:53 PM(UTC)
You are welcome Roger. Keep us posted.
dale farnes
#8 Posted : Wednesday, May 25, 2011 12:25:41 PM(UTC)
dale farnes
hello
i originally posted that i was having a problem with my ice maker overfilling or spilling causing an ice waterfall in the freezer. i fabricated a cover for the fill try where the water fill tube directs the water to the freeze tray. so far so good as the problem seems to be fixed. i think that the water was splashing over this tray and cascading down creating the problem. like i said so far so good ill keep you posted
Guest (4)
Ice Maker Over Fills (Refrigerator & Freezer Repair)
by JKOKBOO 11/6/2009 11:27:17 AM(UTC)
