Heat around freezer door, and freezer don't have enough cool.Compressor run too much time.
Originally Posted by: AHUNJ Heat around freezer door, and freezer don't have enough cool.Compressor run too much time. AHUNJ, Pull the refrigerator away from the wall, enough to get behind it. Unplug the power cord and remove the lower access panel(black cardboard) on the back of the fridge. Clean all the debris from the evaporator coils, fan and compressor, also clean any debris on the floor or in the area. Plug the power cord back in, turn on the cold control, and check and make sure the "condenser fan" runs and draws air throught the coils and over the compressor. Good Luck, :) :) :)
