2 Pages12>
Steve Scovill
#1 Posted : Sunday, April 24, 2011 8:17:33 AM(UTC)
Steve Scovill
I have a Roper (Whirlpool) dryer. It has never dried completely in only one cycle and we've always had to run 2 full high heat cycles just to dry one load.
However, now it won't start at all. The cycle knob spins and clicks, but nothing happens when I press the power button.
I've taken it apart, cleaned it and looked for obviously problems but didn't see anything wrong.
Is there a way to tell if it could be the heating element, timer knob or something else that doesn't involve test electric? I simply don't have the tools to do that.
Any help is greatly appreciated!
#2 Posted : Monday, April 25, 2011 2:28:27 AM(UTC)
Replacement parts for RED4440VQ models | AppliancePartsPros.com
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
Could be that the thermal fuse on the blower wheel (Item 7 in Section 3) has blown.
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
If neither of the above work then you will need a meter to go any further.
I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
Steve Scovill
#3 Posted : Monday, April 25, 2011 8:34:59 AM(UTC)
Steve Scovill
Originally Posted by: denman Go to Quoted Post
Unplug the unit.
Are you referring to the "fuse" on the side of the heating element shield?
#4 Posted : Monday, April 25, 2011 8:48:45 AM(UTC)
No, it is on the blower Item7 in Section 3.
Steve Scovill
#5 Posted : Monday, April 25, 2011 8:52:10 AM(UTC)
Steve Scovill
Okay...I'm new here. What is Item 7, Section 3?
#6 Posted : Tuesday, April 26, 2011 12:19:45 AM(UTC)
Open the link to the parts breakdown that i included in my first post.
It has sections and itemized parts.
Steve Scovill
#7 Posted : Friday, April 29, 2011 6:10:12 AM(UTC)
Steve Scovill
I'm going to give it a shot this morning since I'm off work. Is that thermal fuse easily accessible from the back of the dryer? It's a little hard to tell from the specs.
danintennessee
#8 Posted : Monday, July 18, 2011 4:26:29 PM(UTC)
danintennessee
Unplug the unit.
I have checked the door switch, the starter switch, the fuse and the receptacle. I have power to the cord connections but the dryer will not start when the button is pushed. Any other suggestions?
#9 Posted : Tuesday, July 19, 2011 1:55:58 AM(UTC)
danintennessee
See the attachment for the wiring diagram.
You are missing the last digit in your model number, the above is for a VQ0.
If you have a interior drum light and it is working then you have the power to run the motor.
If not. You did not say what your results of the power check was so I would do the following first just to make sure the power is OK.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
If the power is OK, unplug the unit and check the BU/BK timer contacts.
If that checks OK then with the unit unplugged tape one meter lead to Neutral at the plug/line cord and leave it there.
Then work your way back through the units components till you find the open circuit.
File Attachment(s):
RED4440.pdf (506kb) downloaded 8 time(s).
danintennessee
#10 Posted : Tuesday, July 19, 2011 1:12:07 PM(UTC)
danintennessee
danintennessee
If OK
If OK
Voltage at the receptacle is fine. Voltage at the terminals is fine. The overload device reads 0 ohms and the door switch shows continuity when pressed. (I don't have a light in the drum). I don't know what to check next.
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
Dryer won't start all the time (Dryer Repair)
by DaHadster 1/10/2017 12:25:28 PM(UTC)
2 Pages12>
