tikka2
#1 Posted : Monday, April 18, 2011 5:35:53 AM(UTC)
tikka2
My Maytag washer works well. Recently, it had to be moved (was pushed/pullled 10 feet) and now when it goes into spin cycle, it spins excessively fast. All other functions are working normally.
#2 Posted : Monday, April 18, 2011 6:24:07 AM(UTC)
This cannot happen. The speed is set by the pulley diameters and the synchronous motor. Only way is if the line frequency went up which is not possible unless you have a portable generator.
tikka2
#3 Posted : Monday, April 18, 2011 7:49:20 AM(UTC)
tikka2
It's interesting that you mention a portable generator. I'm in a part of the world that got knocked around by tornados a couple of weeks ago. I was running the house for 2.5 days by running generator through the dryer's 220 line to power the fuse box.
We didn't do any wash but that line the washer is on was hot via the generator.
tikka2
#4 Posted : Monday, April 18, 2011 1:46:23 PM(UTC)
tikka2
First, thank you for responding. You were correct. I had to power the house via portable generator due to tornado taking out utilities. The washer was on a hot circuit but never started.
What needs to be repaired/replaced to eliminate the excessive spinning velocity?
#5 Posted : Tuesday, April 19, 2011 12:46:35 AM(UTC)
Only way is to run the washer with 60 Hz, no repairs possible.
tikka2
#6 Posted : Tuesday, April 19, 2011 11:38:29 AM(UTC)
tikka2
I'm not sure if I understand your statement. I was under the impression that 110VAC-120VAC 2 cycle 60hz is standard at the outlet and that is what the washer is running with.
