With the dishwasher door both [COLOR="Red"]open OR closed [/COLOR]the 'heavy wash"," rinse only" and" auto clean" cycles buttons light when pushed, but the washer does not start.
When you press Auto Clean it lights up and the other lights turn off.
could it be the door switch or the latch assembly?
thanks for any advice
Originally Posted by: Gene  REPLACED DOOR SWITCH AND LATCH ASSEMBLY. SAME PROBLEM BUTTONS STILL LIGHT EVEN WHEN DOOR IS OPEN OR WHEN THE DOOR LATCH ASSEMBLY IS NOT INSTALLED
Run the tests as described in the attached tech sheet and post the results. Gene.
