The Control Panal Fades On And Off. The Call For Service Light And Over Temp Lights Are Not On.the Refrig Temp Is About 55 Degrees And The Freezer Is About 7. There Is A Beeping That Is Coming From Around The Power Supply. The Unit Is About 5 Years Old.ive Tried The Master Reset And That Didnt Work. Could It Be The Power Supply Board
I would replace the power supply board AP3181855, most likely failure.
thank you i will give a try and let you know how it works
