acarpenter33
#1 Posted : Saturday, April 9, 2011 8:31:59 AM(UTC)
acarpenter33
All of a sudden the washer in spin cycle stopped letting the water drain out. Took the pipeing under the washer that goes to the pump off, cleaned it, nothing is blocking the water from draining. Put back together, still doing the same thing. I took the vacuum off and when I suck on it, it holds pressure so could it be either the lid switch or drain pump.
bevil45181
#2 Posted : Saturday, April 9, 2011 10:43:27 AM(UTC)
bevil45181
If you advance the timer to spin and press start do you hear the pump motor attempting to spin? Also, if you move the timer to wash/fill cycle will the washer begin to fill and lock the door? If you are confortable working with electric I recommend making a patch cord and sending power directly to the pump motor to see if it will begin pumping. Check these out, then repost.
Ge dishwasher will not drain (Dishwasher Repair)
by Handyman924 2/24/2017 8:05:27 PM(UTC)
maytag washer will not drain water (Washer Repair)
by mathy10544 12/13/2015 8:54:09 PM(UTC)
GE front load washer will not drain (Washer Repair)
by Sandmann01 6/22/2015 1:24:04 AM(UTC)
Washer will not drain (Washer Repair)
by Artnlp 5/3/2015 7:34:59 AM(UTC)
Washer will not drain in Normal cycle (Washer Repair)
by rober luck 4/20/2015 9:10:47 AM(UTC)
by charles140 10/10/2014 8:21:01 AM(UTC)
by hurler72 11/25/2013 10:59:35 AM(UTC)
topload washer will not drain or spin (Washer Repair)
by olac757@gmail.com 8/9/2013 9:08:21 PM(UTC)
Whirlpool dishwasher will not drain (Dishwasher Repair)
by PeterZ 8/6/2013 7:21:51 PM(UTC)
Washer will not drain or spin (Washer Repair)
by Fixit Dad 5/23/2013 4:26:49 PM(UTC)
by PepperVal 5/16/2013 8:36:29 AM(UTC)
Whirlpool Washer will not drain unless open and close lid (Washer Repair)
by twhistle 2/28/2013 8:16:58 AM(UTC)
Washer will not drain or spin, new pump and lid switch (Washer Repair)
by tangerine30680 1/26/2013 12:42:38 PM(UTC)
I replaced lid switch, still washer will not drain or spin (Washer Repair)
by dnschrstn 11/12/2012 12:39:16 PM(UTC)
washer will not drain before the spin cycle (Washer Repair)
by tondot 11/11/2012 5:32:56 PM(UTC)
