Help! Recently moved washer won't hold water!
Thanks so much for the suggestion. The drain hose IS much lower than it was previously. I bet that is the problem - can’t wait to try it this evening and see!:slight_smile: But if it doesn’t work, I’ll be baaaaack…:rolleyes: (laundry is piling up! :o ) Thanks again Nat! - SusieQ
