mrod40
#1 Posted : Friday, March 25, 2011 8:17:46 AM(UTC)
mrod40
dryer heats up with no load in it. when i put in a load the heat shuts off and it keep on tumbling and never dries. i cleaned the exhust duct all the way out of the house, is this senser or regulator or what?
Jeff / APP Team
#2 Posted : Friday, March 25, 2011 11:32:30 AM(UTC)
Jeff / APP Team
Hello. Check the coils and see if they test good. You can test the coils using a multi-meter. The two prong coil will read 1,000-1,300 ohms, and the three prong coil will read 1,300-1,400 ohms across prongs 1&2, and 500-600 ohms across prongs 1&3. Let the dryer run for a few minutes and then check them. Hope this helps.
Part number: AP3094251
