Mariannesmith
#1 Posted : Tuesday, October 7, 2008 8:47:16 AM(UTC)
Mariannesmith
The washer is making a high pitched noise on the spin cycle and also on the wash and rinse cycles. No noise when filling. Underneath the washer on the floor is a ring of spattered grease with some white powdery shavings on top of it. I have checked the spin bearing by starting the spin cycle and immediately using hands to prevent the tub from spinning. This does not affect the noise - it is still there. What could the problem be?
libertyappl
#2 Posted : Tuesday, October 7, 2008 9:48:34 AM(UTC)
libertyappl
Stopping the tub like that is dangerous. but this is a belt driven machine, the belt is located under the washer, if you are stopping the spin cycle, by hand then the belt is being forced to spin on the shaft of the motor, making it likely that it is either the belt slipping, or the motor bearings, in the rare case that the belt is not slipping on the shaft of the motor, but rather on the basket drive pulley then the problem could be in the pump.
Mariannesmith
#3 Posted : Tuesday, October 7, 2008 10:17:32 AM(UTC)
Mariannesmith
I removed the belt, which seemed fairly tight. I checked the pump pulley and it moves easily. it does not spin freely, but it is easy to turn. the amount of grease on the floor is substantial, and it is in a ring shape centered around the central pulley.
libertyappl
#4 Posted : Tuesday, October 7, 2008 10:25:13 AM(UTC)
libertyappl
There is only one part of a washer that has oil/grease, that is the transmission. If you have a substantial amount you tranny is probably going out.
Nat
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
Maytag atlantis half works (Dryer Repair)
by BDR1783 5/3/2024 1:04:26 AM(UTC)
Maytag Atlantis MAV7700AWW motor? (Washer Repair)
by Guest 4/1/2023 7:45:13 AM(UTC)
Kit 12002213 for Maytag Atlantis washer MAV7600aWW (Washer Repair)
by Shaun W 2/12/2021 7:34:30 AM(UTC)
Maytag Atlantis washer - MAV6200AWW (Washer Repair)
by Tidasu 1/17/2021 10:06:08 PM(UTC)
Maytag Atlantis agitates during spin cycle (Washer Repair)
by Brent99 9/15/2020 10:38:11 AM(UTC)
Maytag Atlantis MAV7700AWW Washer occasionally not dumping water (Washer Repair)
by pzazzera 6/30/2019 7:37:02 AM(UTC)
Maytag Atlantis Dryer Ignites, Blows Gas/Flame then shuts off (Dryer Repair)
by pzazzera 5/16/2019 6:19:39 AM(UTC)
Maytag Atlantis Will Not Run (Washer Repair)
by Bsktbll 10/28/2017 5:29:38 PM(UTC)
Maytag Atlantis Washer is dead and full of water (Washer Repair)
by mtaylor4242 1/28/2016 2:57:43 PM(UTC)
Maytag Atlantis Washer will not spin (Washer Repair)
by lvavis 8/26/2015 7:56:10 PM(UTC)
Alternate timer for Maytag Atlantis dryer (Dryer Repair)
by thorning 7/21/2015 1:37:27 PM(UTC)
Maytag Atlantis only spins on high speed (Washer Repair)
by davidsg99 6/1/2015 9:07:15 PM(UTC)
Maytag Atlantis new timer not working (Dryer Repair)
by blewis123456 11/5/2014 8:26:45 AM(UTC)
Maytag Atlantis Dryer timer which one? (Dryer Repair)
by Stevenerd 10/21/2014 9:52:18 AM(UTC)
