craigapple
#1 Posted : Friday, September 26, 2008 7:23:57 PM(UTC)
craigapple
I have my dryer all torn apart to put a new motor in, but I can't get the blower fan off the threaded end of the motor shaft. I don't want to torque on it too much because I'm afraid I'll break it. Is it a left-hand thread?
Thanks!
Craig
kayakcrzy
#2 Posted : Sunday, September 28, 2008 2:48:49 PM(UTC)
kayakcrzy
Bear down on it, and unscrew it. That is the only way. Tom ApplianceEducator.com
greenthumb25
#3 Posted : Wednesday, November 25, 2009 7:17:47 AM(UTC)
greenthumb25
is there a cheap way to fix a wheel motor? i don't think i have the money to have a overall rework done
#4 Posted : Thursday, November 26, 2009 5:25:27 AM(UTC)
Replace it.
Once it is stripped, it is toast.
monkeybiz
#5 Posted : Thursday, July 29, 2010 9:03:35 PM(UTC)
monkeybiz
I found I was able to get mine off by placing a wrench on the hex nut behind the motor and resting the handle against the idler pulley shaft. Then I put a vice grip on the motor shaft in front of the motor and whacked it clockwise with a hammer. you could use a sturdy piece of wood. It came off. If that won't loosen it you will have to use a screwdriver from the motor side and literally bust the plastic of the fan blade off of the motor shaft.
