After using the self clean cycle, the oven will not heat in bake, broil or another self clean cycle. There are no errors on the display. The oven acts as though nothing is wrong. I have a parts list, but am unsure of which part is at fault or what parts to test. :confused:
Please post advice. Thanks!
Updated - after posting this I found another thread which mentions the Thermostst (TOD) (item #37 in the parts list) as the most likely part at fault. I will try replacing that part first. Thanks!
Update 2-15-2011, I replaced the TOD and it now works fine!
