Douglas Poole
#1 Posted : Thursday, February 10, 2011 5:37:05 AM(UTC)
Douglas Poole
Is the clock (control board) difficult to replace??
Joe / APP Team
#2 Posted : Thursday, February 10, 2011 9:07:50 AM(UTC)
Joe / APP Team
Douglas,
No, not really,
Here are your part numbers(you may want to consider a key pad as well).
and the instructions on the repalcement procedure.
Part number: AP5176341
Part number: AP2126499
To remove the backguard back panel:
1. Disconnect power from range.
2. Remove six screws and lift the panel off.
NOTE:
Screws may be removed using either a 1/4” nut
driver or an S1 square drive
To remove the electronic oven control:
1. Disconnect power from the range.
2. Remove the back panel from the backguard.
3. Disconnect the wires and harness from the
control board.(make sure you label the wires/connectors).
4. Remove the four screws. (One from each
corner).
Reverse procedure and check for proper operation
Douglas Poole
#3 Posted : Thursday, February 10, 2011 9:37:29 AM(UTC)
Douglas Poole
Thanks for the quick reply and assistance!
Joe / APP Team
#4 Posted : Thursday, February 10, 2011 11:15:19 AM(UTC)
Joe / APP Team
Douglas,
Thanks for allowing us to assist you,
It was our pleasure.
