Is the clock (control board) difficult to replace??
Originally Posted by: Douglas Poole Is the clock (control board) difficult to replace?? Douglas, No, not really, Here are your part numbers(you may want to consider a key pad as well). and the instructions on the repalcement procedure. Part number: AP5176341
Part number: AP2126499
To remove the backguard back panel: 1. Disconnect power from range. 2. Remove six screws and lift the panel off. NOTE:
Screws may be removed using either a 1/4” nut driver or an S1 square drive
To remove the electronic oven control:
1. Disconnect power from the range. 2. Remove the back panel from the backguard. 3. Disconnect the wires and harness from the control board.(make sure you label the wires/connectors). 4. Remove the four screws. (One from each corner).
Reverse procedure and check for proper operation
Thanks for the quick reply and assistance!
Originally Posted by: Douglas Poole Thanks for the quick reply and assistance! Douglas, Thanks for allowing us to assist you, It was our pleasure. :) :) :)
