I originally got an error code on my oven. I replaced the control panel now the whole oven is without power. What did I do wrong?
Hello, We may need a volt meter to test the oven. double check all of your wire connections on the board, if they are good check the power coming into the oven with a volt meter. Next I would verify that the control board is getting power, if so the board is bad. Appliance Repair Technician:
