dscott1000
#1 Posted : Friday, August 29, 2008 10:59:26 AM(UTC)
dscott1000
I had the usual problems with my Bosch d/w--cycles wouldn't end, etc. Replaced the control module today after a lot of wrestling to put the door back on. Flipped the breaker, turned the unit on, the lights lit, the display worked, but I could not hear any water coming into the machine and the cycle wasn't starting even though the display was counting down. I tried to run diagnostics but am not sure I pushed the right combination of keys--got nowhere with that. Can anyone help? This is incredibly frustrating after thinking I had the problem solved after a lot of work. Thanks in advance for any help!
indytricia
#2 Posted : Sunday, November 1, 2009 5:13:11 AM(UTC)
indytricia
This is the exact problem I am having. Anybody have the answer?
