wHIRLPOOL WASHER 2000 LA555OXPW3 WHEN TURNED ON THE WATER COMES STRAIGHT OUT AND i DO NOT KNOW HOW TO TELL WHERE ITS COMING FROM..iS IT THE PUMP OR SOMETHING ELSE?
umm..what is the cabinet? my washer lid is on top and its hooked up for the water to run outside..are you talking bout moving the washer to my tub? and wat am i looking for? lol
The cabinet is the top, front and sides. See the video.
I am not sure I understand your reply. I assumed your problem was that when you started the washer water came out from underneath it. If not see if you can give us more detail on what your problem is.
yes thats what its doing..ill see if i can check it out then reply back to you
