With The Knobs Turn Off The Igniter Keeps Clicking
Originally Posted by: gary yencer With The Knobs Turn Off The Igniter Keeps Clicking Was this post ever replyed to and problem solved or not. I have same problem and would like to know the answer. thank you
what is the venturi for on a GE gas range #egr3001ej1ss?I HAVE NEVER HAD THAT PART ON MY ORIGINAL EQUIP.
Originally Posted by: curtisjones what is the venturi for on a GE gas range #egr3001ej1ss?I HAVE NEVER HAD THAT PART ON MY ORIGINAL EQUIP. HELLO ANYBODY HOME?
I NEED HELP REPLACING MY GAS BURNERS On a GErange#EGR3001EJ1SS ,my original equip. did not have a venturi so is that part neccasary?
is it neccasary to buy parts that are not part of the original equpment,venturi GE range #egr3001ej1ss?
On my GE cook top it was water in the control knob area. I took knobs off, and with a blow drier dried both the knobs and the are around the control shaft out and that solved the problem.
