2 Pages<12
rlmcmillen
#11 Posted : Monday, November 29, 2010 6:54:00 PM(UTC)
rlmcmillen
Originally Posted by: denman Go to Quoted Post
Yes you can get a line cord and attach it across the timer motor.
If the timer advances odds are very very high that it is OK.
But then I think the odds are very high right now that the board is shot.
Just make sure that the machine is unplugged while you do this or you could end up with a big arc and spark.
Thanks a bunch Denman. I just ordered a new dryness display. Hopefully that fixes my problem!
#12 Posted : Tuesday, November 30, 2010 12:59:37 AM(UTC)
I will keep my fingers crossed.
kayakcrzy
#13 Posted : Tuesday, November 30, 2010 3:10:36 AM(UTC)
kayakcrzy
Originally Posted by: rlmcmillen Go to Quoted Post
I'm not an electrician, but my common sense tells me that it has to be that circuit board. I was kind of baffled when I put in a new timer and put it on a timed cycle and it didn't advance, so that makes sense that the board runs the motor regardless of the timed vs automatic cycle. Any way to test it without trial and error with a new board?
It does sound to me like the board also. I have no idea how to test it. I usually carry one, to swap. I am an appliance repair man. With all this electronic, half the time I am a parts changer. Tom ApplianceEducator.com
rlmcmillen
#14 Posted : Saturday, December 4, 2010 6:38:53 AM(UTC)
rlmcmillen
Thanks so much Denman!!! I fixed it for $45 and a few headaches. It was the sensor display board.
#15 Posted : Sunday, December 5, 2010 2:26:44 AM(UTC)
You are welcome
Glad to hear that you got it up and running.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
hot point dryer no heat and timer doesn't advance (Dryer Repair)
by gooseofdeuce 4/18/2015 8:29:56 AM(UTC)
timer doesn't advance in Auto Dry Regular mode (Dryer Repair)
by Jake53 1/10/2014 1:43:08 PM(UTC)
Whirlpool gas dryer, no heat, timer doesn't advance (Dryer Repair)
by jeffmaaske 8/31/2011 5:30:21 PM(UTC)
Tub fills, timer doesn't advance (Washer Repair)
by yahuwoody 7/2/2011 3:08:12 PM(UTC)
Maytag Atlantis timer doesn't advance (Dryer Repair)
by colby 3/29/2011 9:08:24 PM(UTC)
Timer doesn't advance (Dryer Repair)
by sdrake 7/5/2010 7:37:26 AM(UTC)
Maytag timer doesn't advance to Spin automatically (Washer Repair)
by John Burgess 7/23/2009 5:36:57 AM(UTC)
washer fills, timer doesn't advance, nor does it agitate, spin, or drain (Washer Repair)
by threads68 6/9/2008 10:17:17 AM(UTC)
2 Pages<12
