Hello all, I have a Frigidaire LTF2940ES2 front load that has a door lock code E41. I replaced the door switch in the last month and all was well, but apparently its bad again. Is there anything that could be taking this switch out?? $80 a month is going to get expensive!!
THIS FORUM IS DEAD!!!!!!! |
Thanks DenMan, it was a loose plug on J2. I appreciate the help!
This thread is helpful as my washer is stuck on the E41 door lock error. I'd like to see if there is a loose connection or if I need to purchase a new door lock assembly, but I am embarrassed to say that I don't know how to find the control board. Do I pull off the front LED Display to reveal a circuit board? I have looked over every manual I can find... Thanks!
