Hello everyone. I am in the process of getting ready to replace my very old GE Model GSD900G-01 dishwasher. I do not have the manual, and therefore, do not have the dimensions (Width and Depth). I have found the use and care manual online for this model, but nothing in that describes what I need.
As a last resort I figure I can pull it out and measure it, but wanted to first see if anyone had this information easily accessible?
I cannot find this info but it should be easy to measure by just pulling the kick plate off.
Also it is the size of the opening that counts not the size of the dishwasher. Often filler strips are used to make the unit look better.
One thing to watch out for is tiling. Often people install ceramic tile with the dishwasher in place and depending on the tile height getting the old unit out becomes a major problem. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: Lery  Hello everyone. I am in the process of getting ready to replace my very old GE Model GSD900G-01 dishwasher. I do not have the manual, and therefore, do not have the dimensions (Width and Depth). I have found the use and care manual online for this model, but nothing in that describes what I need.
As a last resort I figure I can pull it out and measure it, but wanted to first see if anyone had this information easily accessible? All Dishwashers are a standard siae. They are 24 inches wide. Any new one will fit right in the place of your old GE. Tom ApplianceEducator.com
Originally Posted by: kayakcrzy  All Dishwashers are a standard siae. They are 24 inches wide. Any new one will fit right in the place of your old GE. Tom ApplianceEducator.com Excellent, thank you so much for all the replies.
