Johnson15
#1 Posted : Friday, November 5, 2010 3:53:17 AM(UTC)
Johnson15
Have set the freezer temperature control knob to ZERO and the temperature of the freezer is at minus10 degrees F. It has been as low as minus 30 degrees F. ( Refrig side is set to 4 and is not a problem). I was able to set the freezer control at 1 for a while but now it's requiring a ZERO setting. I'm afraid I've run out of adjustment. Is the ice maker thermostat controlling the freezer temp or is it something else? Note: I replaced the ice maker motor about a year ago and the main elect control board a month ago (for a refig lighting problem).
Johnson15
#2 Posted : Sunday, November 7, 2010 1:48:16 PM(UTC)
Johnson15
The door seals are sealing very well. The parts diagram shows a thermostat 627985 located in the icemaker and a thermistor 2188819 in the refrige control box (Whirlpool Model # GD5RHAXNB00). I assume there is a problems with the temp sensing mechanism in one of these parts. Which will affect the freezer side? Thanks.
pgc
#3 Posted : Monday, November 8, 2010 7:04:26 PM(UTC)
pgc
sounds like the freezer temperature control (thermostat) needs replacement
