cbsmark
#1 Posted : Wednesday, November 3, 2010 5:40:37 AM(UTC)
cbsmark
Little or no flame. Tapping on valve/regulator assembly allows gas to ignite with normal, full flame for about 10 secs. then it goes out, no gas flow. Need to wait 10-15 secs before tapping to get gas to flow again (for about 10 secs)
Valve or regulator? I see some are sold together as one assembly.
Thanx!
magician59
#2 Posted : Wednesday, November 3, 2010 6:44:52 AM(UTC)
magician59
Is this a top burner, or an oven/broiler?
cbsmark
#3 Posted : Wednesday, November 10, 2010 4:42:21 AM(UTC)
cbsmark
Intermittent oven burner. Bottom (oven) burner, not top (broil) burner
magician59
#4 Posted : Wednesday, November 10, 2010 5:27:28 AM(UTC)
magician59
Try cleaning the ports in the burner assembly. It may be easier if you remove the burner, so you won't have to stoop to do it. Use a toothpick, or similar instrument. Don't use anything that will enlarge or deform the holes.
If all the holes are clear, and you still have intermittent operation, you may have a weak igniter.
