GE Washer Squeaky in Agitation cycle
Thanks for the reply. I read about this issue too when I went to the page you referred me to before I came here where I also read about the suspension rod issue. I was just questioning whether it could be the apron since it makes that squeaking sound when I just manually turn the basket in the machine when it’s off and since it does NOT make the sound during the gentle/delicate cycle. I was thinking that it would more likely be the suspension rods if I can recreate the sound just by manually turning the basket when the motor isn’t on, but I’ll have the apron checked. If it’s just a simple repair kit, perhaps my husband can do it himself as he’s quite good at fixing things…it’s just finding the time! :slight_smile:
