[FONT=Times New Roman][SIZE=3][COLOR=#000000]This is a problem that GE should repair free of charge and I have so far been able to get them to do so when I see this problem even if it is out of warranty. What happens is the apron (which is just a metal brace that holds the tub up) is bending down and the bottom of the motor is hitting the bottom of the washer. They have a repair kit for this that is not hard to install but I feel they should send someone out at no cost to you because this is a factory defect. This is not something that just failed or broke it was destined to do this from the start.[/COLOR][/SIZE][/FONT]
[SIZE=3][COLOR=#000000][FONT=Times New Roman] [/FONT][/COLOR][/SIZE]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]I am not trying to bash GE or throw them under the bus because I like GE this is just a problem they should take care of for you. So give them a call and tell them you have the sagging arpron issue and would like to get it repaired. This page talks about this problem GE HydroWave Noisy Washer Repair Guide[/COLOR][/SIZE][/FONT]
