HELP.. please.. Washing machine and a burning rubber smell
[quote=Amy Johnson;275379]Hi Gene,
Thank you for you help.. we will give that a try.. do you feel confident without seeing or smelling what is happening that this is the problem? I really appreciate you assistance and help!!!
Amy[/quote]
Amy,
Worn out belt is pretty common cause of such smell, but you have to inspect it to verify if it is correct.
