brooksw
#1 Posted : 15 years ago
brooksw
The electric when off in house , when came back on oven door would not open , Wife jerked it now cleaning latch stuck in open position oven will not turn on to bake or broil cycle
#2 Posted : 15 years ago
Does it show any error code on the display?
Pull the range out of the wall and check the switches on the door latch & motor assembly (#89 on the diagram). Post the results.
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE FGF353BADA Frg(v2) / Gas Range | AppliancePartsPros.com
