dogman203
#1 Posted : Wednesday, August 25, 2010 1:43:01 PM(UTC)
dogman203
Dryer quit tumbling, still heats. Found broken belt, and a broken pulley on the motor shaft. Have replaced the belt, and pulley. Now, the motor hums after hitting the start button. If you manually advance the drum (give it a push) the motor will keep it spinning ... drum is empty, have not tried loading it ... guessing motor is bad? Is there a means to test? or, any other items I should check? Thank you! :)
kayakcrzy
#2 Posted : Wednesday, August 25, 2010 4:06:02 PM(UTC)
kayakcrzy
You need a new motor. Tom www.applianceducator.com/parts.htm
