bbuckvi
#1 Posted : Tuesday, August 24, 2010 8:58:24 AM(UTC)
bbuckvi
My Maytag DE312, series 02 has stopped producing heat. Two questions:
1. If I replace the Thermostate (part# AP4036890) and the Heater Assembly Complete (part# AP4290655) have I replaced all the parts that can prevent the dryer from producing heat?
2. What side of the dryer do I access the heating assembly and thermostate?
Thanks,
BBuckvi
Joe / APP Team
#2 Posted : Tuesday, August 24, 2010 12:05:20 PM(UTC)
Joe / APP Team
Thanks,
BBuckvi
BBuckvi,
1) Replacing the thermostat and heater assembly, will probably solve your
no heat situation.
But No, There are several other parts and wiring involved in the heat
circuit(timer, Regulating thermostat,and the wires between them all).
2) You access the heater and thermostat by removing the front panel.
Unplug the machine at the wall,
remove the 2 screws from the lower area of the front panel(kick plate
area) and lift out on the bottom of the panel and panel will unhinge
from the top assembly.
Unclip the door switch wire harness from the panel so you can move the
panel to the side for easier access to the heater and thermostat,
located on the right side of the base , under the tumbler.
Reverse the procedure and test for heat.
Good Luck,
topup from th
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
